1G pop up lights wont go up
xx1gdsm
34
Apr 25, 2010
lakeland, Florida
last night i tried to pop up my light but they didnt want to go up.....my lights work fine but didnt want to pop up i pressed the button and nothing......need help
I can pretty much guarantee it's the plastic socket on the end of the actuator has cracked and the ball joint on the headlight housing fell out.
Try just lifting the headlight with your hand. If you can then the actuator has come off. It's a bit of a Pain in the ^$$ but you can pry the thing back on if it's not too badly cracked or you'll have to find a replacement at the salvage yard.
..or the relay in the box by the passenger shock tower is bad...
+1 My pop ups didn't pop for the first 5 years I owned my car. The i changed a couple of the fuse/relays in that box (trying to fix something else) and they started working and have been working ever since (about 2 years). I'm not sure which fuse/relay it was though, sorry.
no i dont think its my relays i was just messin around and they flipped up i had the car off and just put the high beams and they flipped up
