- Thread starter
- #51
InfiniteGSX
- 3,182
- 16
- Dec 10, 2002
Tijeras,
New Mexico
Well I don't know how the car will handle now, but I know for a fact better than it would before. Since all the car would do is slide nose first into a hard corner. This is the type of driving I was raised on, due to living on 50 miles of S Curves from the city to my parents house. I rather enjoyed my Negative Camber.
And then My car doesn't move at all due to the car sitting on the tire. I have a MM of space from my tire, to the inner fender. If I were to lift the car, which I will NOT because this is the whole reason I did it.... It still wont make a difference because of how wide the offset of the wheels are. Under hard launches, cornering, bumps, the tire will hit the fender. Causing damaged fenders and severely damaged tires.
All when you could spend <$40 on some longer bolts and washers for the upper control arm mounts.
. Dude the car looks good but don't expect tires to last more than 2 months at the most.
