Which port goes where on turbo?
The cooling line that comes off of the thermostat housing goes to the rear of the turbo center section[it's the supply line], the front cooling line for the turbo center section comes off of the coolant pipe, which runs from the water pump [aka the turbo coolant return line].
And as mentioned above the oil supply line is indeed the top port on the center section of the turbo, the bottom tube is the drain line [as you already know].
to make it easier to understand oil comes into the center section from the top, and out from the bottom, coolant in from the back out from the front.
[edited: sorry for any misinformation, I was kinda in a rush when posting this]
The cooling line that comes off of the thermostat housing goes to the rear of the turbo center section[it's the feed], the front cooling line for the turbo center section comes off of the coolant pipe, which runs to the water pump [aka the turbo coolant return line].
Fixed.
Good answer. Im putting in a new turbo next week and you just saved me a search.
