2G Port on manifold
RevyDSM
38
Apr 16, 2016
Dayton, Ohio
I was wondering if this was a Wideband o2 or just a regular AFR. The connected yellow cable goes back into the firewall and is spidered through out the underside of the dash. sorry for bad quality
Are you sure it's not an EGT sensor? Hard to tell from the distance of the picture, but typical EGT location, not typical for AFR.
Can't really tell, it goes into the back of my pillar pod from under the dash and I'm pretty sure that it's for the AFR even though its in a weird spot. I'll have to pull the pod or follow the wire to see exactly where it goes tomorrow.
