What is this called / Where does this go / What does this do? [MERGED]
forcefed594
Aug 8, 2009
Pittsburgh, Pennsylvania
This is probably a dumb question, but what is the part called that holds the front suspension in place and bolts up to the knuckle in a 1g? Does anyone know where i can find this part? :hmm:
Trying to figure out my no dash light issue, I saw this hanging under the dash. What's it for?
I bought this car from a friend, and I found out it used to be auto. Im going through and cleaning things up as best as I can. I came across this and hsvent been able to use the search function to find a thread to tsll me watT this is. its a 97tsi if that helps...just a wire hanging with what seems to be a relay thats supposed to be bolted somewhere?
Got it when I bought my 1g turbo parts could I use this to tap into the coolent so the turbo has a coolent feed or does any one no what it's for thanks ,1g plymouth laser rs wouldn it work in the spot in the second pick?
So I looked in the hatch of my GSX that I bought about a month ago and found these parts. Looks like some stuff that's been replaced. Can someone tell me what all it is. Obviously one is a belt tensioner and there's a belt and turbo gasket. What's the other stuff??
To be precise the 1g CAS is a crank and TDC sensor (as per service manual), it assumes cams are timed correctly with the crank. It is indeed installed at the end of the intake cam.
I was cleaning my new to me 95 eclipse took apart the center console not sure what this battery looking thing is under the back cup holder. If anyone could tell me what it is and does. I'd greatly appreciate it.
