What is this called / Where does this go / What does this do? [MERGED]
forcefed594
Aug 8, 2009
Pittsburgh, Pennsylvania
This is probably a dumb question, but what is the part called that holds the front suspension in place and bolts up to the knuckle in a 1g? Does anyone know where i can find this part? :hmm:
You can find more details here
the two nipples are the thermo valve that actuates the EGR (most likely gone or blocked on your car), the sensor as stated before is the A/C water temperature switch (again A/C has been most likely removed on your car since the harness to the compressor is not connected in the first pic).
Run a line from your wastegate to your manifold or to your j-pipe nipple. Do you have a nipple on your j-pipe?
What is this for?
What is this for?
This will set your boost level max technically to what the wastegate actuator is at. Usually 9-11 depending on stock turbo you have.
From other pics you have posted, im assuming you have a 6 bolt water neck and thermostat housing. The white sensor in second pic is a/c temp switch for 1g cars.. you dont need it on your 97. As far as the connector check out http://www.dsmtuners.com/forums/art...047-2g-engine-bay-electrical-connections.html
i cant remember what that is for actually..ill look it up later.
Where does this vacuum hose go? It is right behind the fans near the bottom, passenger side.
this is on the drivers side firewall looks like a vacuum should be on there.
this is middle firewall looks like both vacuum nipples are broken off.
The one on the bottom goes to your Throttle where it is labeled PEA. That is where the E and A attach.
The top vac line attaches to your intake. There should be a small nipple it slides on.
Did someone remove and cap all of your evap system?
If they did, this should not be a problem.
i have no idea what was done to the car. I believe it has a 6 bolt swap. Top and bottom? They are left and right.
Oh just take the damn thing off were not trying to find the circumference of the thing but rather the diameter. Not trying to find out how long the circle is around. Take the clamp off and put a tape measurer down the middle of it and theres your answer.
Pipes are measured in DIA NOT CIRCUMFERENCE
Millman your right
Hey guys I'm putting on my suspension and looking up torque soecs but i do t know what the items I'm looking for are called to refrence the specs
First is the horse shoe in the front suspension that connects to the strut tower sheet metal with two bolts. Fhe upper ball joint attaches to the horse shoe. Whats that called? (Upper arm shaft assembily mounting nut?)
And i also need to know what this is called and or torque specs shock damper fork to shock mount?
This bolt is to the sway bar end link and need to find the spec on that (stabilizer nut?)
I know the torque specs are here but i dont know which is which LOL
