- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 16g
- Drivetrain
- FWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- K&N filter
Injen Intake
Stainless Tubular o2 housing
NGR BOV
Rebuilt ported 2G head - new guides and seals
Megan Racing 3" downpipe
3" Exhaust - turbo back
Sickspeed catch can
Earl's Performance SS Brake lines
Power Stop cross drilled and slotted rotors
Halman MBC
Brian Crower 272 Exhaust cam
Walbro 255lph pump
Evo 8 560cc injectors
MHI Evo III Big 16G
Punishment Racing FMIC
HKS Turbo Timer Type 1
1G Black Top CAS
cruise control delete
AC delete
Balance shaft delete
EGR/Evap Delete
FP exhaust manifold
Evo III intake manifold w/ coil bracket
1G 60mm throttle
Fuelabs 818 Fuel filter
Fuelabs 515 fuel pressure regulator
Stainless Steel -6AN fuel lines
Custom built fuel pump bulkhead
ARP Headstuds
- Mods-Engine
- 1992 6-Bolt Block,
Balance shaft elimination kit
- Mods-EMS & Logging
- AEM Boost -35hg - 35psi
AEM Oil pressure
AEM UEGO Wideband (upstream mounted)
ECULink V3
Evo 9 MR 1.5 bar boost gauge 1.5"
Evo 9 MR voltmeter 1.5"
- Mods-Handling
- Front and rear upper strut bars
Evo 8 Brembo front rotors and calipers
17" Konig Backbone on Yokohama S Drive tires 17x7.5 +38
- Parts Wishlist
- BC 268 intake cam
Kevlar timing belt
- Background
- 300hp goal @ 20psi
