What is this called / Where does this go / What does this do? [MERGED]
forcefed594
Aug 8, 2009
Pittsburgh, Pennsylvania
This is probably a dumb question, but what is the part called that holds the front suspension in place and bolts up to the knuckle in a 1g? Does anyone know where i can find this part? :hmm:
Unfortunately The part numbers are worn off. however I can tell it is Omron. What happen was I cut it off when cleaning up my harness.. Im sure its not the headlights because they turn on as well as turn signals brakes and parking lights and heater blower and power windows and locks... checked everything,anything im missing let me know.. I thought about the alternator but ive been cranking the car on a single charge for quit some time now so that has me baffled and the cooling fans turn on so im still in a twist.. ahhhhh dsm!!:banghead: edit: Generator relay is 100percent right thank all of you MY next question is do I need it or can I rewire the alternator to run the car this part is difficult to find
Anyone know what this is? I was looking at my engine bay and noticed this plug not connected right. Never replaced one so not really sure what it is our does... Thanks
It's a solenoid. Probably a fuel pressure solenoid or a purge valve solenoid. If the car was originally a California car it may be a egr solenoid.Since they have the vacuum hoses routed into both ports. Has the emissions equipment been deleted?
Ok thanks. Another question: my car is rough starting up, like I'f I don't give it has for a few mins it will die right away. It is throwing a code for a nap sensor circuit and an 02 sensor circuit. Could either of these be causing the issue? The guy at the auto parts store said probably not but I wanted to check here. Btw it's a 6 bolt swap
One of those could be the oil low pressure switch... It mounts to the oil filter housing. Then a little 6" wire plugs into it and connects to the top of the oil pressure switch. Looks like a bell somewhat.
Previous owner included this with car. Not sure where it would go?
It is a small hose, the picture makes it look bigger. Notice the flat spot on the hose.
Thanks
It's a little tube, it fell out around area if oil pain, oil filter. I have no idea. Where it came from just looked down and there it was.
Ive ran my 14b without it but it wont hurt to have it on, just make sure you tighten the coupler onto the turbo inlet. Its just a coupler to me.
Looks like the inlet piece that goes on the turbo, I had one on my 14b years ago, is it about 2 inches in diameter?
^ +1, that being said.... thats alot of oil on there! finger that out asap.
This is underneath the center console behind the ash tray and cup holder. It was unplugged the whole time and did not know it. I plugged it back in. I want to know what it's purpose is. Thanks for the help.
LOL! good thing that didd'nt give you an explosive surprise!
next time ask, get answers then plug it in. ive been KO'd by an airbag doing the same thing... airbag deploy when not actually in an accedent and not being strapped in = very bad day for your face. simalar to this emodicon... :banghead:
