1G What else should I replace while replacing the oil pan?
PlumOne
Apr 17, 2017
Brighton, Colorado
I’ve decided to keep my car instead of selling it. I’m stubborn and not giving up. Anyways, I still have a oil leak after drilling and tapping my return line to my oil pan so I’m ordering a whole new pan and oil return line from STM. I noticed my oil filter housing is leaking as well so I’m ordering a new one with a gasket.
My list so far
Oil pan
Oil return line
Return line gasket and bolts
STM stainless steel oil pan bolts
OEM six bolt oil filter housing
Oil filter housing gasket
4 oil squirters
Is there anything else I should be replacing while I have the oil pan off? Suspension/steering wise I still need coil overs, axles, wheel bearings. Rotors, brakes, tie rods/ends, ball joints, control arms are new.
I think the only other thing left to replace while you're still in there is the small gasket between the oil pickup and the oil pump. It will be accessible with the pan off. Also give the oil pickup (strainer) a closer look and if it's damaged or too clogged, try to fix it. Wouldn't hurt. And lastly since the pan will be off, check if your flywheel inspection cover is there. On AWD cars it looks like a triangular plate, on FWD cars I believe it's a bit rounder.
My list so far
Oil pan
Oil return line
4 oil squirters
Why would you replace the oil squirters? Just in case, if you want to replace the whole oil squirters, you will need 4 jets, 4 check valves and 8 washers.
And as for the oil filter housing, from where is it leaking? If the oil filter housing itself is not damaged physically, you may not need a new housing. Just a new gasket and a proper installation would possibly stop the leak. Before ordering the parts, you should make it clear where the oil come from, so you may be able to save your money.
IF you take the oil squirters out, as @DSMPT said, you will need at the minimum of 8 aluminum crush washers to reinstall and if you have them out, make sure they are not clogged. Blow thru the end with your mouth and make sure they flow, if not, I can tell you how I clean the gunk out of them. Really no need to remove them tho unless you just want to check them and clean them.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
