What cams are these? [MERGED] Cam Identification ID
2gAWDTalon
651
8
Jun 25, 2006
Warner Robins, Georgia
ALL CAM IDENTIFICATION QUESTIONS MERGED HERE.
Cams are not easy to identify for obvious reasons...but if you think it's worth posting pics along with measurements and specs of the cams you're using, give it a shot.
I have these cams, they came in a head I bought. The guy said they were aftermarket and he did not know what kind... does anyone reconize these markings? Thank you very much for any help you can give, I want to sell them but I do not know what they are.
Thanks for the help, now if I can get some pics of the 60 trim turbo maybe I can figure out what it actually is. I got this car in a trade from a friend and he had picked it up from someone with no documentation of what was actually in it. Anyway, thanks.
so can anyone tell me if these are Brian Crower 272 cams? i have intake AND exhaust cams.
pix of bc 272? there are other markings
"1" "ES 4604" "D1" "G" and on the other side of where it says BC101-EX is says "DIK9" thats on the exhaust cam
Intake CAM: from sensor end up to the cam gear "2" "ES4604" "D1" "G" (the BC logo i think) then it says "BC101-IN
can someone verify?
i was asking about if it needed upgraded valve springs and ratainers so i could have other people that are Running BC 272s to come here and tell me.... thanks for the "use the search" reply, question still stands...can you run stock valve springs and retainers or is there need for upgrade?
I run a stock valvetrain with my bc 272's. You want to upgrade spring and retainer based off how high you are going to be reving i have my rev limit set a 7500.
My apologies for not comprehending your inability to access Google.
BrianCrower.com | RunBC.com // Mitsubishi // 4G63
briancrower.com said:
BC0101 272°/272 Street/Strip Specification
Plug and play application. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec. OEM spring OK.
bummer....... was there no marking like the pic?
since this has been resolved (i think) but i dont want to make another thread... does anyone know if these BC 272s need adjustable cam gears? i dont wanna mess up my fresh build. so far i got that stock valve springs and retainers are OK... now jus needa know bout dem gears
So I recently bought a 90 talon tsi manual, and was given receipts for a "new" used machined head. I have the motor out to replace some things and took the valve cover off to inspect it. I noticed i have two different cams, the exhaust cam has "A" and "A 1" sideways stamped into it by the cam gear as well as "E" and some numbers towards the CAS end. and the intake cam has no markings near the gear only an "R7" and "0" near the CAS. I am posting pictures so hopefully someone can tell me if these are the stock cams or what car they came out of. Thank you!
Intake Cam
Exhaust Cam
nope, bu i found out after i put the cams in and i didnt read this forum on time :(
You dont necessarily HAVE to have gears, but your car will run better and make more power if you have the ability to degree the cams because the aftermarket cams arent always machined perfectly and can be a few degrees off. Couple this with a resurfaced head and or engine block, and headgaskets of varying thicknesses and your timing geometry will be far from perfect. There are also people who believe in using the gears to dial in the cams without actually degreeing them in order to optimise specifically for their setup.
Quoted from Keltalon:
A forced-induction engine should idle smooth when properly tuned, and a naturally aspirated engine should be “lumpy” and have a lope if it is tuned aggressively towards the high-RPM range. If a forced induction engine is loping at idle, fuel is being wasted, turbo spool time is being increased (more lag), and power is being lost.
This thread is very interesting and informative, particularly post# 51
And a link to the thread:http://www.dsmtuners.com/forums/cylinder-head-short-block/361516-cam-test-i-will-dyno-test-delta-hks-272-delta-k272-bc-272-cams-2.html#post152119389
OK I have 2 sets of cams one set has no markings on it except a 27 and then behind can gears 272 is scratched into it but no brand anywhere. The other set has a b in one spot and a g in another but no markings saying a duration. Any ideas on this
