Please Support JNZ Tuning
kchaazz's Laser RS Turbo AWD
Ownership Status
Currently Own
Plymouth Laser RS Turbo AWD
Turbo Type
GT35 Variant
Build Type
  1. Street
Forced Performance HTA Red, 8cm housing, internal gate
2G MAF with K&N filter,
FP intake pipe,
Punishment- Racing FMIC
3" ss mandrel bent turboback exhaust W\straight pipe,
Punishment- Racing 2.5 o2 housing
Jay Racing 340lph pump
Fuel pump rewire,
Fuelab AFPR
Fuelab -06 Filter
FIC 1100cc injectors,
Greddy Type RZ bov,
Sk2 PRO cam gears
Mods-Engine
Balance shafts removed,
ARP head studs/stock gasket,
BC 272 cams,
1mm os valves unshrouded,
BC springs and retainers- head built by Bogus SVO
Mods-EMS & Logging
Tuner Pro RT logger,
Hallman EVO RX boost controller,
Eprom ecu with custom chip: extended maps, 11.0:1 afr,55k sb, 55k nlts, 2g maf comp, inj. comp, ipwc elim.,octane reset, fc elim., pk elim
Mods-Drivetrain
Southbend TZB/SSX clutch,
ACT flywheel,
Kaaz 1.5 way front differential,
EVO rear differential with TRE HD Ninja side cover,
TRE 4 spider center differential,
TRE built stage 4- entire EVO III gearset,
Cable and shifter base solid bushings,
JNZTUNING short shifter,
Rebuilt driveshaft,
Torque solutions solid driveshaft bushings,
Prothane motor mounts,
SS clutch line
Full polyurethane bushings throughout, including front and rear subframe and mustache brace,
Jay Racing rear toe eliminator,
RM front and rear sway bars,
New endlinks/balljoints/inner and outer tie rods,
BC BR coilovers,
Noname front and rear strut tower braces,
SS brake lines,
3000GT VR4 front brakes,
Drilled and slotted rotors front and rear.
Parts Wishlist
Magnus cast manifold, built 9:1 bottom end.
  • Like
Reactions: Little man
kchaazz
Comments
Rating
5.00 star(s) 2 ratings
More in 1G DSM
Share this Vehicle
