What cams are these? [MERGED] Cam Identification ID
2gAWDTalon
651
8
Jun 25, 2006
Warner Robins, Georgia
ALL CAM IDENTIFICATION QUESTIONS MERGED HERE.
Cams are not easy to identify for obvious reasons...but if you think it's worth posting pics along with measurements and specs of the cams you're using, give it a shot.
I have these cams, they came in a head I bought. The guy said they were aftermarket and he did not know what kind... does anyone reconize these markings? Thank you very much for any help you can give, I want to sell them but I do not know what they are.
If your not able to verify what those cams are exactly,and want to know. I will run them in our cam dr program for free you just pay freight.
ok just picked up a set of used cams from a member on here ---can any one tell me how to quickly identify a turbo cam from a non turbo cam ------ als0 can any one positively tell me if our non turbo exhaust cams are the same as the turbo cams?.....I do know the intake cams are different == please need a responce asap
any one?......im just seeing if there is a way to tell ----a sure fired way that is
Yes they are different, but not that much. You shouldn't even notice it unless your trying to make serious power.
Intake Lift mm(in) Service limit
Id Mark: A,D 35.49 (1.3972) 34.99 (1.3776)
Id mark: B,C,E,F 35.20 (1.3858) 34.70 (1.3661)
Exhaust
Id mark: A 35.20 (1.3858) 34.70 (1.3661)
Id mark: C 35.49 (1.3972) 34.99 (1.3776)
Id mark E,F 35.91 (1.3744) 34.41 (1.3547)
i am posting this for a friend, i looked but could not find anything
i got a head about three weeks ago for free, the guy knew nothing about the car, when we got it home we noticed a largely stamped B on both cams on the front and rear of each cam... when the cam is flipped it also is imprinted with A1 and 20.....
i even tried looking on google but found nothing
thanks:thumb:
here are the pics
Anyone please, I neeed help!
def stock, i just installed my BC 280's a bit ago and saw no markings like that
I will probably be buying this engine off of a guy but I am getting sketchy information about what cams are in it. He thinks they are Crower 272's but not sure. Id like to know either way but googling the numbers on it aren't getting me anywhere. Here are some pics I took, hopefully it is the info needed. Thanks for any help that can be given
cwc is formally Campbell Wyant and Cannon Foundry Co. they sell blank cams to company's that then machine them to the right specs
the cc could stand for crower cams but i would figure it would be bcc for brian crower cams
idk someone with experience needs to chim in on this one :D
