CrackedDSM
- 5,833
- 5,733
- Dec 17, 2009
Pensacola,
Florida
I think everything that's been said covers the 'theory' portion, but I'll just throw this out: theory doesn't really tell you much about fun.
My v1 68HTA setup is a lot of fun to drive. It's very simple - the turbo has its stock housings but I got JusMX141 to make me a Mitsubishi/Holset hybrid wastegate actuator (back when he shipped to Canada), with FP cast exhaust manifold, Evo III o2 housing, PTP turbo blanket and a manifold blanket. It's on a crummy self-tune and a Blitz SBC i-D boost controller, but it gets going very quickly and boost control is rock steady at 21 psi to redline with a relatively low duty cycle. You could stretch it out on E85, you could port the turbine housing and o2 housing, and it would make very respectable numbers.
I honestly think that 400WHP is where things start to go off the rails with these cars. It gets more expensive, things start to break more often, and that early torque is what makes cars fun. When you transition away to higher power, it doesn't necessarily feel as fast or engaging. You're getting a car that's faster when you really get on it, but in a street car, most of your time is spent putting around below 5,000 RPM - not squeezing the car past 7,000. The v1 68HTA is the best of all worlds, really. It matches a stock engine just as well as it matches a built engine with medium-ish cams. It didn't spool any slower than my Evo's 'Big 16G', yet it still feels like it transitions a bit smoother and has more airflow potential up top. It's the ideal bolt-on street turbo, and just happens to be one of the cheapest.
What do you think about an FP Green as a street turbo? My thoughts are it would be a good middle ground street turbo, and the extra lag would help manual transmission life. Full disclosure I’ve never even ridden in an FP green car so I have no clue about their manners.
But you’ve got me sold on that V1 68HTA.
