Turboed_talon_tsi
- 34
- 5
- Feb 23, 2022
North Dakota
I recently repaired my header/turbo gasket because it was causing a boost leak. Before it ran fine under boost and only ever reached 16psi with the leak. Once repaired I notice a quicker spool and also a whole lot more boost. Car is reaching way more than it can handle and the motor isn’t getting enough fuel to keep up. I messed with my boost controller and set it as low as possible but the same issue occurred. I think the boost controller is faulty but not sure if it could be something else. Thanks!
