Bigbeanbird
5+ Year Contributor
- 249
- 166
- Jan 5, 2020
Mentone,
California
Hey gang, got some questions about a timing belt change.
Why would I have to undercut the tensioner arm so the tensioner pulley would rotate enough to get proper 25 in lbs?
This would be rotating the pulley counterclockwise, now, just for shits and giggles I rotated the pulley in a clockwise direction, (holes being on the top instead of the bottom) and it seemed to work, IE:: no binding. As far as I know it is a 97 GST, could it be a different block? I know there are 2 kinds of arms and maybe 3 kinds of tensioners, really lost and friggen mad.
Any help would be appreciated and for sure used. Thanks a ton
, right parts no grinding.. so true.. I’m kinda new to the DSM turbo game.. when I tried to torque counterclockwise, the tooth side of the belt was actually hitting on the tensioner arm bolt ( well the washer anyhow)..a screw story right now, but,I went clockwise and things lined up and tension was good.. think it’s ok to run it like that..??
- thats pretty
