casuprock
- 320
- 3
- Apr 13, 2010
Exeter,
New Hampshire
The OEM knock sensor is an accelerometer that detects motion in the block after a knock event. This causes many people problems with phantom knock after the stock block is modified or the internals are upgraded. The OEM sensor is designed as an indicator of extreme condition, not as a tuning aid. Additionally, many of the OEM knock sensors are old or have never been replaced. Unreliable data from a knock sensor can range from a tuning headache to engine damage in severe cases.
The acceleration detected by the OEM knock sensor is the result of a transfer function between force and motion in the block. This is sometimes referred to as transmissibility. The compliance (inverse of stiffness, e.g. 1/k) and dynamics (damping coefficient, inertia) of the block are different for forces applied each cylinder. They're also different for each degree of freedom in the system. The block can be modeled as a set of unique stiffness, mass, and damping matrices containing the coefficients of the differential equations of motion (see eigenvalue problem) that describe the block's response from force inputs from each cylinder.
So, in order to use the stock knock sensor to tell if you're really getting knock (and how bad it really is), you have to understand the frequency response of the OEM knock sensor, the frequency response function of the block with respect to each cylinder in each axis, and solve a multi-degree of freedom system of differential equations. Did I mention the damping coefficients change with temperature?
Instead of that nonsense...
You can measure strain (force) in the block directly. Strain is a better metric for determining knock. First, you're not going to pick up motion of the block as noise. Only force inputs to the block causing strain in the axis of a gage is going to excite a response in the sensor. For instance, a location near the crank bearings would be a good place to locate a strain-based knock sensor. It is easier to filter strain data to look for specific force events and their frequency content.
I am using semiconductor strain gages I produce for machining sensors to build a strain gage based knock sensor.
It's not going to be easy.
It does involve designing a sensor from the ground up.
It will take significant testing and determining proper location.
It will be awesome.
It is the Knock Master 5000.
It will be awesome.
