Dashnizzle
5+ Year Contributor
- 163
- 157
- Jun 5, 2021
Montana
There are some plugs / taps on certain OFH that use a British pipe thread size that you can buy adapters for.I’m a little confused still about the oil feed from the filter housing.
Am I going to need a housing from a turbo?
I don’t see anywhere a feed can hook up to my current oil filter housing.
Or does the kit you mentioned tap into it somehow?
This link should give you literally everything you need to know in the world of filter housings including non turbo if I’m not mistaken:
. You’ll probably be happier with the 4g63 intake. Good luck.
