TerminalTalon
Supporting VIP
- 859
- 547
- Apr 27, 2006
Norfolk,
Virginia
My lifted 03 Forester destroyed the axle at 55-60mph. What a noise at random just going to work. Replaced and it’s good to go so far.
My late coworkers kids friend(I know that’s a lot). He got the kid a 93 Stealth and had it painted before he passed so his little crew have a couple. His friend went 3-2 at redline and bent a valve so he pulled this head off the spare engine he has. I need to do a complete rebuild and I guess do the timing and waterpump on it as they aren’t ready for all that.
As the daily went down the truck got to be driven until pets came in. Literally put the axle in and buttoned that up to check the rear brakes on the truck. Ebrake shoes delaminated from leaks so I need those to pass inspection. Drop it and go to move it out. To the floor the pedal goes. Mind you I drove this all week and the line let’s go as soon as I fix the other one. GM still makes brake lines. Move the gas tank over a little. Might as well replace the rear hose also. Should be good for another 288k
Massive oil pan leak on this HEMI Jeep. R&R entire front subframe, front diff and rack per the book. F*ck all that. Remove hardware from motor mounts. Loosen subframe. Jack engine up front the sides in the front. It will give you just enough to get it out by helping the fan shroud.
I was measuring for proper pushrod (what are those?) length. It looks like I need 7.475" for correct geometry. I also cut the baffles out of the valve covers for clearance for the rocker stud girdles.
