Oldsid
Supporting VIP
- 207
- 5
- Apr 26, 2006
Calgary,
AB, Canada
While changing my clutch, I removed the DP and to my surprise it was all "rusted" and it lost a lot of metal (black powder) under the wrapping (see pictures). The wrapping was good quality Cool-it-Thermotec sprayed with high temperature DEI high temperature silicone. I wrapped the DP because it was very close to the oil pan and the alternator.
I know that the wrapping and the road salt probably caused the rust. however, I still want to wrap the DP but to protect it, I want to spray it with high temperature header spray that is good to 2000 deg. F.
I am hoping that by spraying the DP, it will be protected from the elements and will not rust. Do I need a primer before spraying? If so what primer can I use for high temperature like this? has anyone had this problem with SS wrapped pipe?
