johnnyboy55
- 87
- 0
- Apr 3, 2002
Miami / Broward,
Florida
I recently acquired a 1996 gst in which had a head gasket leak. The motor is fresh so i had the head checked and done.. Got a new head gasket and all the timing goodies.. I made a mistake today when installing the the head.. I torqued the head bolts to specs from the service manual but I didnt not put the cam gears on untill afterwards and I noticed everything is timed right except the cams.. I have not put the belt on or rotated anything but I would like to know if I can rotate the cams to get them back in the right timing?? The crank is at tdc but the valves I believe are 180 degrees if Im not mistaken.. They are shut.. I know its a bad mistake but id rather not remove the bolts to remove the head if i dont have to.. Any help would be greatly appreciated..
