Removing Stickers and tape [Merged 2-7]
Status
Not open for further replies.
easiest way for me was using a dull razor and some goo-gone. worked like a charm...OR if you dont wanna take the chance of messing up your paint, you can use something softer like one of those ice scraper things, or a credit card or somethin...
You can use a heat gun or a hair dryer to heat it up a little. Then use your finger nail, razor blade to pick the corner and the decal should peal off. It may come off in a few sections. If you go to a local sign shop they should have a cleaner called rapid remover which is safe to use on vehicles and wont mess the paint up like goo-gone or some other cleaners. Good luck with getting your decal off.
thanks guys ill give it a try i used goo gone to get the black off that came off so thanks i cant use the rep thing to give you's points its not there so ###!
I would suggest Goo Gone i believe its a citrus based product so I dont see it causing any harm but its always a good idea to read the back of the bottle first.
Before starting, look at it carefully under a magnifying glass. Make sure it's not been clear-coated by some repair. If it has, they become about impossible to neatly remove.
No matter what solvent you use to get the glue off dont forget to put a fresh coat of wax on after. No one mentioned it so I figured I would. :thumb:
Hey Guy, when are all these "How do I remove the sticker decals" threads going to be merged into one big blob? :tease:
+1 for the Goo Gone. Used it a lot, it works great. Good for removing the adhesive the holds on the GS/GS-T/GS-X decals too.
Swipe your girls' finger nail polish remover and use a credit card. (swiping her credit card too is not recommended)
nice def. will use goo gone thanks
Status
