roadrunner2176
- 366
- 6
- Jul 26, 2006
South Bend,
Indiana
I re-did the grill on my eclipse recently amidst other work. I found expanded aluminum mesh at Home Depot in large sheets, maybe 4ft. x 8ft. They weren't stored very well and while somewhat stiff still easily bendable and the storage somewhat warped the sheets. I had to find select spots in the mesh that were relatively "lined up" to cut my portions from. I then spray painted them with multiple coats using black gloss spray paint and installed on my car.
I don't have pictures yet as i just did this and the car is elsewhere getting some intercooler damage welded up. I found my solution to be ok but not ideal. Here's why:
1) mesh really isn't that stiff. Anyone pushing on it in the wrong way or perhaps a nice rock could bend it up and I really wouldn't be able to restore it to its original shape, meaning I'd have to cut a new replacement. I'd consider the mesh on my EVO the proper stiffness but I have never found comparable mesh.
2) Spray paint alone just doesn't cut it. It chips off pretty easily and I can tell already that I'll be touching it up a lot. Have to find some other way to coat it so the paint adheres and holds even with small impacts from bugs/rocks/etc. I thought about plasti-dip but I didn't have a quick solution to how the hell I'd dip the grills in it and then a way to dry it
I do however like the general look I got with this mesh. I previously had used a plastic mesh I found in Home Depot's home and garden section used for fencing off trees and stuff. I just turned it at an angle and cut the rectangles I needed out, then made a metal frame out of stereo back strapping for keeping it taut. Over time however it loosened up and looked flimsy. Also the plastic faded slightly over time.
The only alternative to what I've done that I considered was some mesh I'd seen for sale from a vendor on ebay. I unfortunately don't recall the seller's name or any keywords as I forgot the option when I decided to try the Home Depot aluminum mesh.
The mesh you used is for tile. It's supposed to be rough to accept the thinset.
Try looking for some expanded aluminum or sheet metal. You can get pieces in almost any length and gauge. It's stronger and cheaper than mesh, and takes paint very well.
