redeclipse7782
- 463
- 5
- Oct 20, 2004
Worcester,
Massachusetts
Remove the ground battery wire
remove the (4) 10mm bolts that hold the air bag on
Unclip the airbag harness and put the airbag outside of the car
Put the ground battery wire back on
Make sure the steering wheel is completely centered, turn the car on and drive forward a few feet just to make sure.
Remove the large nut that holds the steering wheel on
Grab the steering wheel at 3oclock and 9 oclock and rock it back and forth from side to side until it comes off. DO NOT pull it straight at you unless you want it to hit you in the face. (objects in motion stay in motion)
Put the hub on make sure it is centered, most hubs have an arrow that says top make sure its at 12 o'clock
Screw the steering wheel nut on
Torque the steering wheel nut down to spec
Install the steering wheel onto the hub
