JusMX141
Moderator
- 15,147
- 1,289
- Dec 13, 2005
Greensburg,
Pennsylvania
Anywhere between 0psi and 50psi will do nicely.
....but the flange would be backward if the manifold is designed for the Evo VIII or IX turbo considering the entire turbo is reverse of a DSM turbo or an Evo X turbo.
There's a simple solution to this problem- stop going fast on the Saturdays while I'm at work, and stop breaking shit on the Thursday nights while I'm at the track.Wants to know if Justins going to be at the track with me this year to witness our first 9s pass, since he missed both of my low 10s passes last year???
Atleast Christi was there for the 10.14...
This would work if you could be sure the widespread bolts of the flange are on the correct side to let the Evo X turbo mount up.Ya I know it's reversed on the evos but they say it works. There's even a picture of one installed parts way through this thread
http://www.dsmtuners.com/forums/newbie-forum/391553-evo-8-turbo-1st-gen.html
Hey Justin...I can speak for all 'Tuners', what a great asset it is to be able to tap your brain!
I fed a 14b from the OFH on my 2Gb with no issue, even with a low oil pressure at idle (about 8 psi). Thoughts Justin?must get a 1G "oil feed from head" setup, with stock 1G oil line (has restrictor) -DON'T feed from the OFH)
- can reuse 2G water lines, but will have to swap/bend a little Correct.
- can reuse oil drain, but will have to drill/slot the bolt holes to match 14B, careful when reshaping. If you have a die grinder with a carbide bit, elongating the holes takes 20 seconds.
- must get a 1G "oil feed from head" setup, with stock 1G oil line (has restrictor) -DON'T feed from the OFH) You can feed from the filter housing- many do, but you should be using a .075" restrictor. Unrestricted is just too much pressure and volume for a used turbo to handle.
- Will need to replace existing bolt on 2G head with a banjo bolt setup for Oil feed line. Tighten this banjo bolt to 10-14 ft-lbs ( also 2 crush washers per banjo bolt) If using the head for your feed source, correct.
- need 3/8 in water line hose (2 ft) I prefer transmission cooler hose over regular fuel hose.
- Need J-Pipe (stock 1g or aftermarket) Aftermarket would be preferred.
- Need Gaskets, Turbo-Mani, Turbo-O2 housing, J-Pipe, downpipe, Turbo oil line (both ends) I've re-used gaskets in a pinch and they've worked fine if you cannot locate each and every one.
- need Oil Plug for OFH-3/8 BPT (NOT NPT) ...or you can use a 1/4" line plug where you remove the T25 oil supply line.
- need to put a nipple on the jpipe or turbo. (t25 has one 14b does not) Correct.
Hope this helps.
- Do you always Port the stock 2g O2 Housing-or only if having boost creep I'd say port it anyway while it's off the car.
- Do you always port 2g exhaust manifold-or only if having boost creep Creep has nothing to do with manifold flow. Port the manifold only to match the inlet of the turbine housing.
- Is it worth getting a 7-cm^2 O2 housing? This part doesn't exist- I'm guessing you mean an Evo III o2 housing, which is required only with an Evo III 16G because of the outlet size.
- What is a 'seal ring', where is it used and why? You and the sealing ring will meet once you remove the turbo from the manifold.
- Where to get the "kit" of Turbo bolts with dome washers Not sure.
- Where to get Banjo Bolt and crush washers for head (Mitsu Part Numbers?) Extreme PSi or JNZ Tuning.
- Would you expect boost creep at all if running stock 2g downpipe, high-flow cat and 3" catback? It can be a possibility, but not likely with the stock downpipe.
- Is it a waste of time to port (behind) the wastegate flapper to open to 90, since actuator/rod won't allow 90 degree operation? A complete waste of time and resources.
- If porting the wastgate opening, how much do you open the hole Not large enough that the flapper cannot seal.
- Can you use standard, grade 8 m10x1.25 bolts for the turbo-Mani, or are they a special type? Turbo hardware should be 10.9 or stronger.
- The 14B has stock, 1g O2 housing and exhaust mani included-I assume the 2g's O2 and mani are better performers...correct? 2G manifold = larger runners, less chance of cracking....2G o2 housing = slightly larger wastegate passage and relocated o2 sensor position.
- Are there any mods required to these 2G parts when mating to a 14B? None.
- Will also install a MBC, what boost should this support (w/1G Bov, Stock BCS)? Around 20-22psi peak.
Most guys I know are using the Vibrant v-band kit.Justin I got a quick question you can probably answer quick. I bought an hx40 from you and i got a BEP t3 housing for it with 3" v-band outlet. My question is will the vibrant 3" flange and clamp work on the discharge of this housing. I am talking with JMF about making an 02 housing for me and he wanted to make sure this would work with the turbine housing.
Was this with the balance shafts in place? Your pressure seems awful low at idle for a filter housing source is the only reason I'm asking.I fed a 14b from the OFH on my 2Gb with no issue, even with a low oil pressure at idle (about 8 psi). Thoughts Justin?
Yes, balance shafts were still in place. Part of the pressure problem was that the car had a re-occurring problem with low idle speed, the ISC kept readjusting itself down to about 550-600rpm. Once I switched to the Evo ECU, I simply flashed in a 950rpm idle setting and it held steady as a rock, with around 14-16psi warm oil pressure.Was this with the balance shafts in place? Your pressure seems awful low at idle for a filter housing source is the only reason I'm asking.
I did use a restrictor, although my memory is not nearly good enough to recall what size it was. I was more worried about oil starvation than over pressure to the CHRA.Peak recommended pressure for a MHI center housing is 42-48psi....sourcing from the filter housing unrestricted can give double that on most cars which is fatal for the turbo.
