Questions for Justin...
Twin-scroll tech allows you to use a larger a/r housing (for flow) but spool the same or quicker as a smaller a/r housing. That in mind, if you use a larger a/r twin-scroll housing paired to a single-scroll manifold, you're getting all of the flow that the larger housing can give you but it's also going to be just as laggy as if you were using a single-scroll large a/r housing.
There is also a .70AR housing available but finding information on it is proving difficult after searches. If this housing(when mated to a proper t3 manifold) can produce full spool by 3500-4k rpm and not fall on its face up top it may be an option. Seeing as it is quite larger I am afraid that it may not spool until 5K+ RPM....which is a nono.
Dave ran this housing with a 7-blade HX35 identical to yours on a whooped-up stock 6-bolt a few seasons ago and went 11.60 @ 121 with boost in the mid-20's. Full boost was around 4500, so it was probably as laggy as a HX40 in a bolt-on housing. Keep in mind the engine was very, very tired.
-So how hard is the bolt on .55AR BEP housing going to fall on its face later in the rpm's?
Not really sure- I've never had personal experience with this setup.
-- will I only see ~55lb/min flow or drastically lower?
Probably 55 lb/min at the very best...although this housing and turbo combo has trapped 130mph.
-If I do use the non-divided manifold on the divided twin scroll housing, will the power come closer to 5K rpm gradually, or lag up until then and hit like a drop kick in the back?
Again, no personal experience....but with oversized a/r housings the boost generally comes on very slow.
Since my turbo had thrust play, shouldnt my thrust plate/collar be in pretty bad shape? What else could cause the play? During disassemble process i kept pulling the shaft in and out to see if i could locate the culprit and noticed the collar in the oil shield to be moving in and out as i did this. I dont know if this would be normal or could this be the cause?
Thrust collar is likely junk, yes. The thrust collar will wear into the thrust plate, wearing / destroying both parts.
I'm afraid I would have to concur with Justin on that one.
I went back idk how many pages.I could not find pics of MHI 20g's that I could click and make larger.Do you have any on hand.
I'm gonna redo my search.But my computer is being slow today.:(
This is the turbo I'm looking at picking up for shits ang giggles.The compressor wheel does look a tad wheathered, but would be fine.If not, I think I may just happen to know a guy that can just rebuild it.ROFL
http://s1130.photobucket.com/albums/m539/dsmsource/20g turbo/
Did you ever figure out what turbo I posted up was?
Some monster Garrett that originally began life on a 12+ liter Detroit Diesel. That's what the
on the cover means. Without wheel specs I have no idea- I'm not that good with turbos that are too large for use on sport compact applications.
Hey jus, so since there's not a boost source on the wh1c compressor cover, is it best to just drill and tap for one. Or would it be better to do to the ic pipe. I'm sure both will work but what do you normally do. Thx
It looks like a GT4294.Journal bearing.
Turbo Compressor Turbine
Turbo PN CHRA PN Ind Whl Dia(mm) Exd Whl Dia(mm) Trim A/R
731376-1 712402-7 70.30 94.00 56 0.60 WhlDia(mm) Trim A/R
82.00 84 1.15
Don't quote me on that.But this is why Garrett has a website.Products | Turbochargers
Justin 20g question fixed with the link to photobucket.
I was contacted by the guy with the 20g today.It's a mits compressor housing, with a Garrett BB center section.
Not sure if there a mits turbine and compresser wheel.
But I was very shocked to find out it's a BB hybrid mits 20g.So you get 20g flow and the spool of a smaller turbo, being it's BB.
Being BB, I backed out of getting it.Although it sounded very interesting.
Ohh the top of post 989, was giving Leon what garrett listed as the gt4294, and a link to the gt4294 page.
That's not the specs on the 20g.
BB doesn't mean faster spool. It typically has faster transient response but not necessarily faster spool.
It's a ball bearing 30R Garrett, not a 20G. Don't let the compressor cover fool you.
If you take a hamburger and stuff it into a hot dog bun, then take a photo of it....what will you be eating shortly after the photo is taken- a hot dog or a hamburger?
Ohh so it's a trickster like a 20g inside a 14b cover.Well that's not as interesting as I thought.Pretty glad I turned this down once I found out it was bb.
Mmm hamburger.
Hi Justin.
I have bought two 16G, both come here next week so i dont have compressor wheel diameter for confirmation today.
Vendor
$40 - 16g Core (need rebuilt) - http://i.imgur.com/D7ouc.jpg
$60 - Big 16g Core - http://i.imgur.com/A57kH.jpg
The first look a big 16G "42"
The second look a small 16G ( small compressor wheel )
More pictures:
Gallery 1
Gallery 2
Let me know what you think about the shaved second compressor housing and wheels difference.
I have already a 14B donor for a nice turbine axle/wheel (cracked CHRA).
Another good 14B come here this month.
A brand new complet OEM 14B CHRA
And two rebuild kit from tradergreg
If you can confirm me the compressor wheels needed for the two 16G rebuild, i can bought it and save shipping for the next BigBox comming here in France this month...
Thanks for your time again :thumb:
Remy
That Small 16G needs a compressor wheel and turbine, the Big 16G may be able to be saved but it's not in the best of shape either (shows damage from excessive in/out play). To fix them both properly, you'd need new rotating assemblies for both.
Honestly unless they were super-cheap, I'd pass on this deal altogether and find something with no wheel damage.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
