- Ownership Status
- Currently Own
- Vehicle
- 1989 Dodge Colt 4G61T
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Rebuild S16G / FP manifold ported / MAP O2 recirc / 7Cm Housing ported / Swaintech coated/ Tial MVS/ DEI blanket/ 3P DP with custom 2.5P final exhaust SS/Denso 300Lph/Evo 560cc/Aeromotive AFPR & fuel rail/Fuelab filter/ -6 Russel hose/PWR 6"X8" WAIC/ AFCO Heat exchanger/BOSCH pump/ Home made 6L water tank/AFCO scirocco radiator/14" Spal/FIAV,EGR and PS deleted/Home made alt relocate kit and vacuum bloc/ Forge recirc BOV/custom SS short piping/680 battery relocated to trunk/JMF OCT/B&M oil cooler
- Mods-Engine
- Stock 4G61T 85K miles short block/ARP rod and head bolts/ ACL main and rod bearings/4G67 rebuild head ported myself/Crower valves springs Ti retainers/ engbldr valves and guides/3 angles job done/ HKS 264 exh int/OEM head gasket Permatex copper sprayed/ greengoblin valves cover baffles mod/Bogus oil port mod's
- Mods-EMS & Logging
- Link V3/SD/Boost by gears/GM IAT/Mtx-l/AEM 3bar MAP,Boost,Oil press,Fuel press,Water temp,Volt/Hacked engine harness
- Mods-Drivetrain
- RRE Chromoly Flywheel/ACT 2100 clutch street/ OEM new TOB release fork and pivot ball/Custom stainless clutch line
- Mods-Handling
- Koni yellow /H&R springs/Superpro bushings/ Yoshifab camber plate/Rebuild stock calipers/Ceramic pads/Front SPS modified Brembo discs/ Stainless brake lines/Urethane Liquid engine mounts/A048 tires on stock 14P rebuild wheels/Home made front lower bar
- Parts Wishlist
- Quaife LSD/A048 tires on 15P RPF1/Big brakes kit
- Background
- No plans or goals, only for my pleasure and to find new friends oversea ...
