Pushing/Burning Coolant, Fresh HG - found problem.
ziggo0
774
9
Oct 13, 2009
La Porte, Indiana
Headgasket is a Fel-Pro PermaTorque - it maybe had 600 miles on it. 6 bolt ARP studs/nuts, torqued 30/60/95. Fresh block surface, fresh head surface.
I've had a bit of white smoke here and there, then I started loosing coolant randomly. Was driving through town the other day and saw my temp gauge rise to the top...pulled over, no coolant. I noticed when it's filled up bubbling, rev a little and it wants to shoot out. Pushing coolant - obviously. A WOT pull revealed by a friends eyes blue smoke, mostly on deceleration. It started to get worse so I pulled the head tonight, and this is what I found....
Full Res:
http://www.s01.zi0x.net/misc/IMG_0268.JPG
http://www.s01.zi0x.net/misc/IMG_0269.JPG
Pretty f'd up huh? I did nothing different with this HG compared to others. I've had plenty of Fel-Pro HGs in the past with zero issues. Defective?
Looks to have hurt #2 as well. Are the fire rings ovalled at all?
I've hurt that gasket the same way for multiple reasons but running strong for quite a while now.
After cleaning off the block and head, everything looks perfectly fine - no damage into the block or head. The fire ring does appear to be oval'd right there...not entirely sure how/why - perhaps when I put the head on it bumped and caused a slight out of alignment issue. Either way - the car will be back on the road in about a hour and a half to 2 hours - the new headgasket installed very very well - just finished torqueing it down. Ahhh I love ARPs.
Looks like Detonation. Do you have any recent logs?
After re reading the original post, i'd like to change my vote to this. I somehow missed that the head and block were resurfaced, if that is what he means by fresh.
Yea sorry I wasn't more clear. Cyl 1 & 4 looked perfect.. Now that I think about it, when I put that head on I didn't have my arps already in the block - I set the headgasket on the block - set the head on the block - and the headgasket moved so I had to re-do it. Perhaps I pinched the gasket? Or the second mount it still moved. This time I put the arps in...alligned perfectly.
I've been on e85, 20psi, stock timingg - safety rich. Logs no knock.
I'll say user error caused this - probably was in to much of a hurry
Something beat the gasket out,also check to see if your injectors are dirty. It just doesn't look normal!
They were brand new PTE 1000s 900 miles ago. I'll be doing my hx40 install here in a week or so - I'm going to send them out to be flow tested just to make sure.
Do you have the dowel pins in your block?
Same thing happened to me SAME exact spot gave out on me as well......
Yep. They looked a bit worn but not out of shape.
Did you say you had 600miles on this gasket already when you put it on?
I had about 200 miles when I pulled the head to put my new head on. The gasket I'm showing had about 600 miles before i noticed this was going on. It was brand new when I put it on.
The part number was for a permatorque unless they are naming things wrong.
Something else, if you look at the pictures I took - I haven't touched the headgasket at all. It looks like it wasn't sitting on the head right to begin with.
Ahh...well, it is AutoZone afterall. So far things have been good with the replacement HG. As I said before, I put the ARPs in, HG down on that - made sure it was on perfectly, placed the head and back together from there.
Make sure the studs are free in the head bores. Not allowing full clamp force causing the failure . When you put them in with the head on they should go in smooth as glass with no binding on the bore of the cylinder head holes.
