Pushing coolant. But how?
Hiitman
482
4
May 12, 2004
Colorado Spring, Colorado
This is somewhat confusing to me. Only reason I know what this is is because it happened to a friend of mines Porsche. Anyway.
Last week I changed out my SBR G50 with a PTE 60 trim. I also went from a 91 ofh to a 90 and installed an oil cooler. Made some good 3rd gear pulls tuning the car and parked it. This was on Wednesday. Today I go to start my car and come to find out that the battery was low so because of my inpatience I flooded the motor. After going back and forth with pulling the plugs and cranking it with the injector clips off I finally got it started. Idled very strange. My wideband was at about 11.2:1 the whole time. Then my catch can starts smoking. I shut it off, look under the car and see a milky substance. :( Great.
Now this is where I get confused. How would I be pushing coolant without a blown hg? And if the hg is blown, when did I do it? I'm thinking that it either happened at the end of my tuning drive or somehow (just speculating) there was a detonation from all that pooled fuel and it somehow blew the hg. I've never torn apart an engine so that's just a guess.
Thanks in advance for any advice.
It's a 90 ofh. I'm pretty sure they're just air cooled. I blocked off the old coolant lines that ran to the 91 ofh I use to have. The coolant runs through the block and through the radiator. The weird part is the car was fine on Wednesday when I made 5-6 strong pulls while tuning. I had to of done something this afternoon when I flooded it. Here's a pic of the oil.
Might not be anything too crazy. After thinking about it, my oil has been lighter in the past few months. I thought it was the methanol cleaning everything, but the hg could of been going and that new PTE turbo was what pushed it over the edge. Oh well.
Compression test netted me 190-187-190-190.
Do a leakdown test and see what your results are. You could be pushing coolent because of the high bosot levels. My mechanic installed a new MLHG and was pushing coolent the first time he took it to the track. Running his T67 turbo at 28-30psi.
If it is the headgasket make sure you look into getting the head O-ringed, helps stop the coolent from pushign through.
This was also discussed at length on the DSMLink forums, and the conclusion was that increasing the torque on the head studs was a quick fix, although maybe not the best fix.
What headstuds and torque are you running?
ARP's (not the L19s) and I'll have to ask Mike up at RRE when I call him tomorrow.
Ewww.....looks like a horrible biology project gone wrong.
