all black 4G63
5+ Year Contributor
278
51
Aug 5, 2019
Chicago, Illinois
Hi,
seriously is this the clearance that Precision built their turbos at the oil drain adapter? If it isn’t clocked enough the compressor housing will hit the -10 fitting “the bolt that is”??? This is a PTE oil drain adapter for -10an
Is this the way it is with these turbos?
Also anyone use two -10 straight adapters to run the oil drain? Basically it’s offset to the oil drain on the pan so I really have no choice…..it’s has to make an almost 90 turn at the pan…
Get an @MorrisonFab drain. They make angle fittings and much easier to use flex hose. It's just a drain, no high pressure there. The AN fittings are just too bulky, I know, I ran a 12AN. The MorrisonFab set up is the way to go. Check out their site HERE.
It makes me nuts that they're still using bolt-on T04S cover tech all these years later with those six 5/16" x 3/8" bolts that yank the threads out of the housing the second time they're torqued.
But yes, this is what you're stuck with...as mentioned the Morrison full-3/4" drain is what you'd want to use here.
