Products the DSM crowd would like to see made
-full aluminum radiator tig welded for the 420a engine 5 speed manual set up that is a direct bolt in without modifications with two slim line radiator fans
-One piece aluminum intake manifold with ported runners and holds up to a 65mm throttle body for the 420a (venom use to make one but is no longer available)
-65mm throttle body direct bolt on for the 420a engine
-420a stroker crank shafts 87 to 90mm throw (callies had a 90mm stroker crank but was recently discontinued)
-Direct plu-n-play ecu for the factory 2g 420a engine with some nice features and auxiliary inputs and outputs
-new interior trim panels offered in a variety of colors (door panels, trunk panels, rear quarter panels, door trim panels, ect.)
-New body kit rear bumpers for the 2g talons without having to do an eclipse rear end swap (swapping in eclipse tail lights and such)
It's too bad they didn't design the shock to attach to the spindle rather than the arm. As it sits though, the best solution is an aftermarket arm with a stronger outter balljoint. Which is definitely doable, but I doubt most people would be willing to pay for it.
Is there a good and bad place on these to put an adjusting section? I spoke to my boss today to see if he could help me design an adjustable Unit so he wants to see one so going to borrow my friends from his spare car. And as we can use 3g wishbones I dont think I should look into this unless it would be worth it?
Some advise and tips would be helpful or possibly diagrams
It's been done/started don't know if he finished it. Forum member pepper? I don't have time to search for it.
a twinscrew type? I have seen a few garbage eaton M62 setups that don't make sh*t for power..but thats all.
Any chance for a link?
I'd like someone to make the clear 1gb headlights , you can not find these anywhere that hasn't been discontinued.
Also a metal houses corner lense
I've been thru 2 pairs of the clear corner lenses because the crap plastic snaps like a friggin chip.
It looks disgusting when my headlights are old and then the corners are brand new clear plastic.
Brasso and an old sock.Hand polish the 1gb housings.Youll have to do this at least twice a year,but it flippin works.
Your looking for clear ones ehhhh..Evil laugh..
I'd really like to see someone provide a product similar to the MTEC Shift Springs offered on the K20 platform (RSX Type S, Civic Type S) and the 86 platform (BRZ, FR-S, GT86).
The spring set essentially stiffens up the neutral zone and allows effortlessly quick and accurate shifts.
Review
INSTALL & REVIEW: MTEC Shifter Spring and Pivot Ball - Club RSX Message Board
In Action
https://www.youtube.com/watch?v=jGX9_NNz0Rs
Ah, I remember shifting with one finger in my VW Passat daily driver before I got rid of it. Good times.
You could email thease places to see if they really have them :)
Might be worth a shot.
Mitsubishi Eclipse 92-94 Clear Headlights
Buy Mitsubishi Eclipse 92-94 Clear Head Lamps & Other Car Accessories at ShopCustomCreations.com
First post...
Here's a list of parts I would def be interested in for a 1g
Billet Aluminium front control arm that corrects suspension geometry when the car is lowered, would allow better tie rods and add caster.
A fuel cell similar to the one JMFab produces (that uses stock sending unit etc..) but with a much bigger capacity 15-20 gal.
For Spyder owners id like to buy a
Stock CF Spyder trunk lid
Willing to spend on that!!!
First post...
I love that idea about control arms!!!
Kirkey lightweight seat mounts.
Locating a fixed seat in a car will depend solely on the size of the driver. A bracket set that locates the seat on the same spot for everybody will be optimal for very few. For this, it's always best to first locate the seat for YOU, then fab a set of brackets to attach the seat to that particular spot.
Aside from that, universal brackets do exist as well.
A set of 2G metal door handles to replace the plastic ones from mitsubishi, would be a better fix and longer lasting too and work in cold weather! Once there in no more changing them haha. The ones that used to be sold no longer excist. Or made and stopped being sold in 2010. So would be good to bring them back.
