Products the DSM crowd would like to see made
it would be nice if a company would produce a light weight plexiglass replacement for all the glass in the 2g platform, that would also be compatiable with the DOT and DMV safety requirements but also be track worthy. because all that glass adds a ton of weight
1. All the little trim pieces around the windows that look like hell on our cars.
2. Reproduction interior parts...dashes, doorpannels and such.
3. Complete set of replacement SS brake clutch and fuel hard-lines.
4. total seal or such rings for stock style pistons.
5. A body kit for a 1g that doesn't look like complete ass.
6. A lsd for less than $500,000
7. SFI approved scattersheild
8. +1 on tubular K-Members
9. Replacement quarters, rockers, inner rockers, coresupports, for 1g's
a quarter window air duct panel that replaces the window that allows actual air to be drawn in for ducting, i had seen this made years ago and now i cannot find one!
ive already asked but a bolt in or weld in space framed front end for an easy install!
titanium or stainless cam cover!
1. All the little trim pieces around the windows that look like hell on our cars. jnztuning.net
2. Reproduction interior parts...dashes, doorpannels and such. never going to happen
3. Complete set of replacement ss brake clutch and fuel hard-lines. already available/ jnztuning and street tuned motorsports can help
4. Total seal or such rings for stock style pistons. jnztuning again
5. A body kit for a 1g that doesn't look like complete ass. i dont know how to answer this
6. A lsd for less than $500,000 500k?? If you mean $500 then do you want it to work??
7. Sfi approved scattersheild ThreeSpeed Stainless Steel Scatter Shield (2G DSM AWD/FWD 7 Bolt) - Modern Automotive Performance
8. +1 on tubular k-members 1G AWD Chromoly Crossmember - New Years SALE! - DSM Classifieds
9. Replacement quarters, rockers, inner rockers, coresupports, for 1g's again jnztuning or they can point you in the right direction
Some window vent visors that fit a 2g would be nice
You mean like what the old mustangs have on the rear window? Thats been discussed before and the 2g would look wrong with them only 1gs would look ok with them
#1, 8 Front End
Ditto!:hellyeah:
Dip Sticks with decorative handles. I altered mine to have this eagle on a globe. It was a random piece I found at the dump, and I have no idea what it came from. It just happend to be the perfect size and was metal, so I JB welded it to my dip stick top. Works fine, and looks cool. It would be nice though if you could buy them, and have various options.
- a butterfly brace like miatas get for the 1Ga, 1Gb and 2G, if im not mistaken and they're already around. These would be amazing for TA and AutoX. Here's the link for a pic: Flyin' Miata : Chassis : Stiffening : FM butterfly brace
- something like a 2-way or Fully Customizable LSD for the 1Ga and 1Gb
- carbon fibre front and rear diffusers
- c-pillar bar for the 1Ga and 1Gb, if there isn't one already
- maybe a clean widebody kit, or at least some blister fenders to widen the arcs for the 1Ga and 1Gb
+1 for the carbon fiber rear diffuser
high quality headlights to keep up with the changing design of modern headlights (audi, infiniti, etc)
I wouldn't mind paying $300 - $400 to get an upgrade/modern looking headlights that are OEM quality and fitness.
Can someone sell a 1g radiator with the alignment pins on the bottom spaced for a 2g?
I know I could buy a 1g and cut the pins and move them but thats a pain.
We cant even buy nice radiator hoses, we have to buy both sets for a 1g and a 2g and use one hose from each kit.
If someone sold a 1g rad that fit in a 2g, we could reap the benefits of being able to just buy just a 1g rad hose kit. We would also benefit from the upper hose being routed away from our exhaust manifolds. Being that most of us dont run heat shields.
You can buy rads that are made to whatever you want.
If im going to go through the trouble of designing a rad I mind as well just buy a 1g rad and modify it to fit in my 2g.
The purpose of this is simplicity, order and install...
You know you can run a spyder or 7g galant rad if you want the upper rad hose to be on the passenger side.
You know you can run a spyder or 8g galant rad if you want the upper rad hose to be on the passenger side.
This too. And all you would have to do is measure out the 2g rad abd just simple change the top neck. But if its not aluminum you should just use a 2g spyder or 8g galant rad.
