We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
In the first one, the "Lock at settings 0", I see that it obeys the table whenever BoostPSI is above 0. When BoostPSI is below 0, then the duty cycle is 0. So the "Lock at 0% below" is still actually in effect. That's ok though - for what we're doing we mostly wanted it using the table values whenever the BoostPSI is above 0. Maybe if you really needed it to use the table all the way to the left, you'd put -29.92 in those 2 blanks.
The first log and video also show that the table value of about 60% is enough to make it flutter.
Too bad that it was right on the edge there. So there might be a little more tweaking of the table possible, but not any more great improvements to be had probably from just this work around.Yes it did start to flutter at that point. It happened so late and so quick that it didnt register in my head that it happened until after I put my foot down. I thought I was in the clear. It had to have been right on the edge.
Which is a disadvantage in my mind. Compared to one with an actual MHI 16g compressor wheel.
