2G Oil pump/water pump
Bluecifer361
85
9
May 31, 2020
Corpus christi, Texas
I have a 2g eclipse with the 1g 4g63t swap, I wanna replace the oil pump and water pump while I have the timing belt off. Should I go with all oem parts or is it recommend to go with a high performance setup if I plan on making 600ish whp?
The oil pump is built into the front cover. I wouldn't even bother replacing it as long as you've got good oil pressure. OEM water pump should be fine. If you find you have cooling issues I would start with upgrading the radiator before the water pump. I'm not at 600hp or anywhere near that so I'm sure other guys can speak on that but I see no issues with the stock parts supporting the oiling and cooling system at that power level
The oil and water pumps are part of the rotational assembly... So they don't necessarily need to be replaced in terms of power, but when the rpm is increased. Unless thw engine is modified to require more oil or more water.
