munk
- 161
- 1
- Mar 3, 2008
vassaboro,
Maine
also want to state the car is 100% stock
1990tsiawdtalon links are good reads toohttp://www.dsmtuners.com/threads/coil-pack-check.433254/
Or do like Doug does and grab a live wire and lean against the car, testing for shock...
To me I'd say ignition control first but I'm puzzled at the boost gauge response. You need a meter. You're just guessing and pissing in the wind without it.
HAHA Like a boss.http://www.dsmtuners.com/threads/coil-pack-check.433254/
I agree. If starting fluid didnt make any changes then we are not firing. I would check the connection on power transister or ignition module or what ever that thing is called. And then compression.I don't think the spark matters. If it didn't make any noise spraying starting fluid I would say there is no spark at all. In my opinion no need to look at the plug itself
Could have sworn you said you added fuel manually somewhere.no where ever in this post did i ever say ive used starting fluid i have a buddy coming over with a meter at some point im willing to bet its the ecu as well
