Street Build RestoMod
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
16g
Drivetrain
AWD
Build Type
  1. Street
-Vibrant Air Filter
-Extreme PSI 2g Mass Adapter
-Hacked 2g Mass Air Flow Sensor
-Air Duck To Direct Outside Air to Air Filter
-Crushed 1g Bov
-Hallman Rx Boost Controller(Adjusted All The Way Down)
-Modified Holset Wastegate Actuator with Very little Preload (Set to About 19/20psi)
-Evo 8 560 Denso Fuel Injectors
-Fuel Lab Fuel Pressure Regulator Set To 48psi Base Fuel Pressure
-Walbro 190 Fuel Pump
-Fuel Pump Rewire
-Egr Delete
-Emision Delete
-A/C Delete
-Powersteering Delete and Converted to MR2 EHPS
-Home Depot Racing Exhaust Manifold Heat Shield
-GT Concept Exhaust Manifld With EGT Bung
-Rebuild MHI Evo 16G Turbo With Ported Turbine (No Creap)
-PowerGo Motorsport recirculated o2 housing
-Megan TBE
Mods-Engine
Stock
Mods-EMS & Logging
-AEM Boost Gauge
-AEM WideBand
-EcmLink v3 Full Edition
Mods-Drivetrain
-Evo 3 Rear Differantial
-Evo 3 Axle Cups
-Moded To Fit 4 Bolt Axles With 4 Bolts Cups
-Evo 8 Enkei Wheels
-Poly Bushing On The Front Control Arms
-Poly bushings On Rear Control Arms
-Jay Racing Active Toe Elimination Kit
-Moded To Fit 3000GT Rear Trailing Arms
-Evo Brembo On All 4 Corners(Currentlly replacement rotors with Wagner pads)
-Braided Brake Hoses On All Corners
-Moded To Fit Evo Rear Backing Plates With Brake Shoes And Hardware
-Moded To Fit Upper and Lower Control Arms
-Fortune Auto 500 coilovers with swift 7k springs.
-Custom front upper mounts with caster adjustment.
-Customer upper rear strut spacer with supercar engeniring lower mount adapter.
Parts Wishlist
More Torque.
Background
Repair and Build.
Brembo
Rating
5.00 star(s) 1 ratings
More in 1G DSM
Share this Vehicle
