munk
- 161
- 1
- Mar 3, 2008
vassaboro,
Maine
also want to state the car is 100% stock
Dang I totally missed the cel. He's right this is almost certainly ecu or ecu power related.Holy cow... did no one watch the videos? Or am I seeing it wrong?
No CEL when turning the ignition to ON, no boost gauge movement, both indicative of an ECU problem or no power going to it. OP, you say you don't have a meter so all your checks on the fuses are purely visual and do not really count for anything at all. If you can't check the MPI fuse on the (+) Battery Terminal Box, replace it -- it costs practically nothing. If that doesn't get the boost gauge moving and the CEL to come on, replace the GAUGE fuse in the interior Junction Block. Also check that the IOD storage connector is in place. If not, connect it and try again. You can also try jumpering the necessary wires on the fuse box for the IOD unit to see if it is the IOD unit itself that is preventing power reaching the ECU. See: changing wiring harness. question about one connector
If that still does nothing, I wouldn't bother with much else until having the ECU looked at.
For reference: No spark,tested every every thing.
So update and tell us what it was.
