Seamus
- 589
- 41
- Nov 18, 2002
Eureka,
Missouri
You just like mW because I point out how pathetic landspeeed is.
Well here lately landspeed has been cool. I can say he recently gave me some advice that was right on time. I guess it all depends on how he is feeling on a particular day. On a good day he is alright! But when he is having one of those forum moments look out, its onYou just like mW because I point out how pathetic landspeeed is.
Well its not as bad as you may think. 25psi pull. the car hauls very nicely this can be contributed to the rpm/gear base boost control feature in dsm link. Set the boost lower in the lower rpm and gradually increase to full boost around 6800rpm onwardHow do you make use of that power with FWD?
I am no expert but 700whp and under I can certainly help with! I can tell you what worked for me at all power levels up to 700 and what didn't work as this will save you a lot of time and money. all recommendation for a daily driver.Nice job Kelvin! Now help me make that kind of power
Sic Man!!Well its not as bad as you may think. 25psi pull. the car hauls very nicely this can be contributed to the rpm/gear base boost control feature in dsm link. Set the boost lower in the lower rpm and gradually increase to full boost around 6800rpm onward
Now just what 40psiSic Man!!![]()
Here is the dyno sheet in SAE for all that want to see it
. It's making a lot of power but it's a whole new ball game.Na its not with the cyclone. I heeded your advise and got me a JMF street version SMIM! As far as timing I will see if I can pull it off of link.Care to show what your timing map looks like. I just ditched my little holset for a borgwarner 6266 off a tractor. It's making a lot of power but it's a whole new ball game.
Is this still with the cyclone intake?
I turned it back down to 36psiWorking that turbo a little hard arnt you
Oh those poor little axles and tranny are going to feel the wrath of 590ft lbs of V8 like torque. I feel sorry for those things!!!Well it's really time for some drive shsft shop axels. Then the drag radials!
Yeah it the 4th autozone set. I haven't broken one yet but can't seem to keep the boot together, this is the boots on the tranny side.Oh those poor little axles and tranny are going to feel the wrath of 590ft lbs of V8 like torque. I feel sorry for those things!!!
I've asked the same question.Ah fourth set, oh I wonder why on that side.
. Didn't help me much at least.Haven't been to the track this year yet but i do plan to get a run or two in here soon. I just may give the oem axles a try next. Thanks for input.Seems about right for a 62mm. Are you planning on trying to drive it down the track at all?
Those autozone axles are way worse than OEM. I think you would be alright with a true OEM axle. I also dont think that a drag radial will do much to help make that power work on the street. Didn't help me much at least.
I hear what you are saying loud and clear. I will be upgrading the cams from the bc272 to bc276 sometime this week as well as running a bigger fuel line. Hopefully the cams will drop the torque number enough to eliminate torque concernsGood job. With almost 600 ft lbs TQ I would stay the f*** away from drag radials.
I was on the list for the ga 1/2 event for some reason when the event went live I was bumped out of my slot. I have sent several emails and all they can say is that I have been put on the waiting list and an email will be sent. I was talking with a local dsm friend and he is concerned about me entering the event and the thought of going some crazy speed in the 1/2 without a roll cage. I plan to have a cage before September for sure just incase a spot opens. As it goes the keltalon project still have a few more goals to accomplishSeems about right for a 62mm. Are you planning on trying to drive it down the track at all?
Okay I need some input on fuel feed. Instead of going all out most of you guys know me to be a stepper first. So here is what i am thinking If I just run a -6 feed line from the stock -6 location near the tank to the golan fuel filter and -6 to the magnus fuel rail, should this be enough? Just trying to get some input. I do know anything above my current stock line set up will be an upgrade. Thanks in advance!
If you find out it's still not enough you'll just have to step up to the -8. I think you will be pleasantly surprised to find out how far the -6 will take you though.
