2.3,s362net, big dyno numbers =)
1sick91tsi
149
Feb 13, 2004
pipersville, Pennsylvania
Well I finally got to hit the dyno today. Car is still pushing a bit of coolant but I f' it and went to the dyno anyway. Made out much better then I ever expected. Only thing that sucked was their rpm pick up was messed up so I dont have torque numbers and its overlayed in speed.
Best number at 36 psi was 691hp
wastegate pressure at 26 psi made 584hp
dsmlink logs below
Videos
32psi, 628 hp
YouTube - dsm 2.3 s362 at 32 psi, 628hp pump gas and methinjection
33-34psi 651hp
YouTube - dsm 2.3 s362 33.5 psi 651hp pump gas and meth injection
36psi, 691 hp
YouTube - dsm 2.3 s362 36 psi 691hp pump gas and meth injection
26psi, 584hp
YouTube - dsm 2.3 s362 26 psi 584hp pump gas and meth injection
Dyno sheet, if it doesnt look good enough I will scan is on my computer later.
full mod list
ENGINE:
6-Bolt Swap - 2.3 stroker, eagle crank, eagle rods, ross pistons mitsu mls, l19s
Rebuilt head s.s valves, super tech dualvalve springs, fp2 cams
mosimoto Radiator
bullseye s362net .70 t3 housing
ramhorn manifold
forrester intake manifold
TRANSMISSION:
XACT Chrome-Moly Flywheel
ACT 2900 street clutch
act 6 puck disc
B&M Short shifter
SUSPENSION:
Tokico Struts
Eibach Lowering Springs 1.5"
Front & Rear Strut Tower Bars
toyo proxes Tires
FUEL UPGRADES:
Walbro 255 fuel pump
delphi 1000s
snow performance meth kit, dual nozzels. 625ml nozzel, and a 375ml nozzel stright m5 meth
ENGINE MANAGEMENT:
DSM Link v2.5
evo8 maf setup
EXHAUST:
Apexi N1 3"
Great numbers man. That thing must be fast. Going from 34PSI to 36PSI netted an additional 40HP.. 20HP per pound of boost is very good. I'm sure this thing has more in it too. Good job.
Nice numbers! I am looking into the s366 for my next turbo. Seeing these numbers on a s362 makes me happy. :)
Holy old thread revival!
However it is nice to see such a simple set-up rocking good numbers, no insane fueling requirements, no super high dollar head/cam/intake manifold set-up. I love it. :hellyeah:
Was that the normal s362 or extended wheel? I'm looking for about the same power your making.
Thanks I noticed net wasn't thinking at the time. Anyone know good place to buy a s362 and what divided a/r would be the best to make about the same hp?
