need some help figuring some things out
Talon54981
Aug 22, 2004
Waupaca, Wisconsin
Hi everyone, its been along time since i've been on here LOL. But now i'm back to DSM's. Ok i have a few questions about a 1g I just bought that i'm not familure about or just forgot over time.
1- There are 2 coolant lines on the throttle body where do they go? (i could be mistaken but I think I might have a 2g throttle body on my 1g don't know if that makes a differance. That and its got a turbonetics t3/t4 turbo on it so i don't know if the lines goto the turbo but if that turbo isn't water-cooled?....)
2- How do you find out what size injector it has if they are not Mitsubishi injectors?
3- Can anyone send me a link to a pic by pic or a good version of the 1992-1994 Turbo AWD Manual engine wire harness diagram? I've looked for hours on here and have found acouple but the pics are too small or its the electrictions version that I don't understand LOL
Thank you very much and I hope I get this beast running again LOL. thanks
1. You don't have a 2g tb, it would make no sense to change from the bigger 1g 60mm to the weaker 2g 52mm tb while still using the same 1g intake manifold...unless the Int man is a 2g?
1.5. The stock turbo is water/oil cooled. Aftermarket turbos can come in oil cooled only in many cases.
2. You have to remove the injector to find out. Should say the cc's or at least give you a part # you can Google.
3. Google - try to find a pdf file.
