We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
Actually I messed up when I said his latest log still has those injector cuts during idle at 1400 rpm. I must have been looking at the log before.It's not possible to idle above 1500 if throttle is actually closed. You mentioned cuts at 1400rpm. Betting it's 1500 and what you're describing is idle surge. Log idle position switch. Anytime you're off gas it should be on. At idle if rpm goes up ( leaks etc) rpm hits 1500 but switch is closed ecu cuts fuel. Idle drops and fuel come back on, cycle repeats.
In this latest log (12.30-02) his idle is higher, 1700-1800 rpm, and the Injectors are on all the time, and the Idle Switch is 1 (closed).
So is it strange that it's not cutting under those conditions?
It has a lot of injector off time but it's all when there is 20, 30, 40 mph Speed, RPM appropriate for that road speed, so he is rolling along and taking his foot off the gas, those would just be normal coasting FC which is OK.
But just the fact of it idling at 1700-1800 with the idle switch closed, and 0 MPH, is that "not possible if the throttle is actually closed"? Does that mean pretty much for sure that his throttle butterfly is just not closing all the way? Like the throttle cable is too tight, or the butterfly is hanging up on the body wall? That high idle was happening at 260-335 seconds like Nick said.
The log that does have a whole lot of injector cuts during idle at 0 MPH with the idle switch closed and RPM ramping up to ~1400-1500 then cuts, is the next previous log (12.26-02). I'm not sure where we are at with that right now because there wasn't that type of thing in the 12.30-02 log.
