chrisman287
5+ Year Contributor
- 1,157
- 1,110
- Jul 19, 2021
New York
Looks like you have the same issue as me... alternator isn't keeping up at WOT.What would be causing the knock? These are pics before and during and after.
That worked gary Thank you so much! Highest the knock went to was 3.5 degress and i saw a 15 of boost & have seen 17 in previous drives.. Thank you so much .
What all did that do? Not have the timing be so aggressive? If i had everything in the green would that be safer then having the rest of it in yellow & red?
Here is the log of drive after that adjustment
, and it would be worth looking at. Those are specs that Jeff cooked up that he thought would be good for how my car was at the time, and would still be good for taking more mods, bigger turbo, and probably up to 400 hp or so.Right, we don't get that feature on the 1g.There is no adjustments to be made for the radiator fans on link for a 1g is there? Only on the 2g you can adjust when the fans come on correct?
Right, "Copy to ECU" just saves the page you are on. "Copy all to ECU" saves everything everywhere, all pages.Do I need to save each table after making adjustments before going to the other one? I made the changes to both tables but it didn't save on the min table for some reason
What downpipe is on the car?Yes, I am still on the stock side mount intercooler. In my garage I do have a fmic I would love to put on with the 255 fuel pump & 1,000 cc injectors in garage which in time will happen.
Oh do you think there is a resonator where the cat was originally? In other words, no cat probably?I believe there are 2 resonators in the exhaust.
I will definitely be putting a new alternator on there. Just right now funds are extremely tight and waiting untill I am able to get one. Been thinking about taking the one off my eclipse tho tbh. It needs a clutch and can't drive it so minus well take it offbecause it solves thr voltage issue. only problem is it's cold but it will get done thoI still think your lack of battery voltage is playing a role in this knock situation.
.I feel that. I have a used Galant 90a on the way it was $50 shippedI will definitely be putting a new alternator on there.
. Thr other pic shows the newer alternator installed on the talon.Got it resolved!!! I just disconnected everything and re connected it and bam. Now it all works and reading higher voltage then the original alternator did.
I was in the middle of making a log and my computer died, so I will be making a log tomorrow. So much relief that after the connections everything came back and is working great!!!!!
Those YouTube bastards published it as a Short without even asking me first if I wanted that, which I didn't.
Yeah, I filmed in square aspect, 1:1, but I was holding the phone upright, never thought about holding it sideways!If you film in portrait mode(hold phone vertical) and its under a certain amount of time, it's automatically uploaded as a short.
If you film in Landscape mode(holding the phone sideways) it's uploaded as a regular video no matter how short it is.
Thanks, I will try it someday on an upload.
