We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
Yes, for the intro to that subject, go back to post #389 and read the paragraph where you'll see "50 - 60% throttle pulls" about half-way through the paragraph.could you elaborate on that hose? I wasn’t aware it was hooked up wrong, is it a pain to correctly do it or is that also something I shouldn’t be worried about currently?
It's a little bit of a pain because I think the best way to do it in your case will be to weld a bung into one of the intercooler pipes. Trying to put it into the turbo would be harder to do with it in the car, and even if you took the turbo off, I wouldn't be too wild about having anybody welding on it or drilling and tapping it.
I say a bung because once you have an internally threaded bung in there (pipe threads) you can screw in any type of hose barb fitting or elbow or whatever you need for the hose to fit in the space available.
It could be in the lower pipes or the upper pipes. Mainly just need convenient hose routing from it to the wastegate actuator. Then later when you add a boost control solenoid, that first hose would go to the solenoid, like he shows in the pic in #389. And the second hose would go from the solenoid to the wastegate actuator.
! Doing the request file now!
