We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
Something worth knowing is that 5/16" fuel injection hose fits kind of perfectly over the OD of the steel pipe that comes out of the fuel pump sending unit. So if you had to, you could just saw the fitting off the end of that pipe, slide 5/16" fuel injection hose over the pipe, about an inch, and clamp it with 2 fuel injection type hose clamps like the ones I sent you. It won't leak and it won't blow off either. Mine is actually like that now. I didn't exactly want it that way, but English Racing cut off the fitting on the end of the sending unit pipe, so there it is. It seems fine.
Then the problem is what to do with the other end of the hose. Well, the steel pipe that runs under the car to the stock fuel filter is, I think, the same OD as the sending unit pipe. And that end of it I'm not familiar with because I never had to do anything with mine, or with the stock fuel filter. But it seems to me that you could find a place somewhere where you could cut the pipe and push the 5/16" hose onto it and clamp it with fuel injection hose clamps just like on the sending unit. The pipe OD would have to be reasonably clean of course, still round
, in decent shape. It's something you guys would have to look at and figure out if it's something you could do with the tools available.
You can buy excellent quality modern high pressure 5/16" fuel injection hose, Gates Barricade, 15 feet for $60. I used this hose to hook up my fuel filter, which you can see on my Specs and Photos page.
What I'm saying about where you would cut the pipe on the sending unit is, you'd cut it at the red line here (pic below).
You'd cut it after taking the whole thing out of the car first of course, and you'd have to first cut the rubber hose before you could do that.
, in decent shape. It's something you guys would have to look at and figure out if it's something you could do with the tools available. You can buy excellent quality modern high pressure 5/16" fuel injection hose, Gates Barricade, 15 feet for $60. I used this hose to hook up my fuel filter, which you can see on my Specs and Photos page.
