snowborder714
Moderator
- 16,188
- 465
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
There should be 39 teeth from outside cam mark to outside cam mark.
You can do it yourself!
Connect the positive and negative clips to the battery and the weird clip goes over spark plug wire from cylinder 1 (closest to timing belt). Then you point the gun at the harmonic dampener from the engine bay. You'll point it to the right of the alternator belt. You'll see the timing mark degree indicator on the lower timing belt cover. It can be seen in this thread:
http://www.dsmtuners.com/forums/newbie-forum/264316-t-belt-cover-base-timing-marks.html
With all of the timing marks lined up (cam gears, crank pulley, oil pump), the white mark will be lined up with the 0. Then when you ground timing and shoot the light, you'll adjust the CAS until that white mark lines up with the 5* tick.
Engine Timing
Base Timing Adjustment
blcknspo0ln said:You start counting from 1 at the tooth on TOP of the exhaust timing mark and continue onto tooth #39 which is the tooth that sits directly on the intake cam mark.
Engine Timing
