greekgodchaos
- 565
- 212
- Jul 4, 2007
Vancouver,
Washington
Has anyone tried cutting their lower timing belt cover in such a way that if and when you need to take it off, you do not have to disassemble a hundred different things in order to take 1 cover off? I had this idea a while back and will probably do it to my cover, but here is what I had in mind:
Something along those lines where wherever the cut lines are, it would still allow for as much structural rigidity as possible so you do not have bits flapping about. Im also thinking of maybe fabricating some reinforcement bars/plates to go on the OUTSIDE of it to add more rigidity but also have them clear the outer belts. This is all theory right now and I will be playing around with this idea all the way up until I need to put it on for the completion of my build. I am taking a Solidworks class and I will see if I can come up with a better solution for what I'm trying to do. Any and all input would be appreciated.
Main reason for doing this would be for easy access when it is your DD and you suspect something is running amok down there and you can't access it unless you know what it is you are doing. (Something I didn't know how to do before my build
)Attachments
... Just run it without one plus it saves you like 50 lbs and will give you 50 plus HP due to weight reduction
... No that is a pretty cool idea sometimes those things can be a PITA if they have never been touched before. I say try it and keep us posted
I happen to be one of the lucky ones to own a boroscope so having a hole that would allow me to look around in there, it would probably need to be a 3/4" hole with a plug...but that way you could at least stick a flashlight in there and kind of see whats going on in there.
I will try and get some more sketches made up and hopefully a rendering I can post later this week. Keep the ideas coming though this is great stuff here
Lets get on that chaps
