Farmcar
- 39
- 36
- Aug 6, 2013
Portage,
Michigan
Congrats on the win! Car looks great
. All is well, as I had more time to get the car ready for the PYOP event at Pacemakers, hard tire class.I’ve never seen the tree light straight to green after staging. Car seems pretty consistent and not too bad if you just broken an axle. Are you planning to upgrade axles? Love the car
Ahhhh! PYOP light makes sense. Yikes $1200 just for rears. But I’m sure at those power levels, that’s nothing. We have to pay to play
. The DSS rear axles fit and look great!
. I have a Borgwarner band waiting to get soaked and installed. Starting to look pretty serious underneath the car. Coming along nicely.Got a little bit of an update. STILL waiting on the new forward frictions to put the trans back together, and also noticed my forward drum is cracked! I sourced another drum to use, so I learned how to pull it apart and replace the piston's seals. This will all be on my next post when I wrap up the trans.
While waiting for the frictions, I decided to knock out the driveshaft. While tearing my OEM driveshaft down a bit, I noticed the universal joint was in rough shape, so I just decided to refinish and rebuild the the tail shaft with a new OEM U joint and new OEM carrier bearing and hardware. Not much else to really say here. I'm really happy with how it turned out, I hope it performs as good as it all looks! I love fresh parts!
Thanks for looking! There's more photos attached to this post as well.
View attachment 623170 View attachment 623171 View attachment 623172 View attachment 623173 View attachment 623174 View attachment 623175 View attachment 623176 View attachment 623177 View attachment 623178 View attachment 623181 View attachment 623182
