2G Loose wire
Rohitter7878
92
13
Mar 12, 2022
Greeley, Colorado
I was starting to work on my 95 gst and noticed this wire hanging and was connected to something some time.
Probably to the oil pressure gauge sending unit.
How does it go hooked up to it?
x2, I think I have a spare pigtail that fits the sending unit. Lmk if you need it
What does the pig tail look like?
So it's suppose to look like this and the small thin metal has a connector going to it?
No, you've already got that one hooked up, circled below. There's two different sensors on the oil filter housing, one for the oil pressure warning light (dummy light), and one for the oil pressure gauge. This one is for the oil pressure warning light.
@DSMPT has it circled in his post; that one is for the oil pressure gauge.
It’s almost a T-slotted clip that retains itself over the gauge sending unit fitting(circled in green per dsmpt’s post). Best pic I could find for now. The pigtail means it has the appropriate clip and enough wire in the harness to tap into your existing wire to complete the original circuit.
Thank you guys for your responses, I looked over the thread but alot of the pictures don't come up, so I'm still lose. Could one of you guys take a picture of yours on how the wire goes connected to the sending unit, that was I can figure out what kind of end piece I need to crimp to hook it back up. Thanks guys
Negative on the spare, I must’ve used it on on another car- although if you want to hook it up another way you can use this in the picture. Available at any hardware store, it will slide on but won’t have the retaining clip that the original connector had, so it may fall off while driving.
OK I just have to improvise then ha..
