Resolved Looking for lead on 4G63 N/A oversized pistons
lglracer
Supporting VIP
326
106
Jul 13, 2008
Sacramento, California
Hello Everyone!
I'm rebuilding the engine on my 90 Galant GSX and need to find .03 over pistons and having a hard time finding them. Anyone have any leads on N/A Oversized Pistons. Thank you!
Which N/A pistons, you need the same as Galant GSX? There are various and are you specifically looking for OEM or OEM replacement pistons for stock 6 bolt rods? If so, NPR, Enginetech, DNJ, Topline etc etc. They have oversized 6 bolt N/A pistons.
Or if you are ok with aftermarket forged pistons, then custom pistons. You can make your desired compression ration.
I don't know if it's still available but NPR part number for 0.75mm/.030" oversized N/A piston kit is 10-540-3.
I am looking for OEM Replacements for stock 6 bolt rods. the car is 100% stock and I want to keep it that way. Ive looked down the path of going with a evo 8 piston since its the same compression but a good aftermarket oem replacement will be fine. I went with NPR for my VR4 but having a hard time finding them in no turbo applications and in a .03 oversize
You should ask Rockauto or some store that carry DNJ or NPR (NOA) products, if you can order part number P107.30 (DNJ 1G 6 bolt non turbo .030" piston), PR107.30 (DNJ 030" rings) or 10-540-3 (NPR .030" piston kit). Or maybe ask directly to DNJ or NPR of America. I think they are the only ones who can supply .030" oversized OEM replacement pistons.
Mitsubishi used to have .030" oversized pistons but I think it's not available anymore, and usually It's hard to find .030" over pistons with aftermarket off the shelf kit. It's because like I explained in the link below.
Don't you consider to cut cylinders for .040" oversized pistons? It would be much easier to source the pistons.
I was actually just looking at @RockAuto and they do have .03 and .04 on the site for the non-turbo from ITM Engine Components. Looking at the picture it does say 63D which indicates non turbo. I think im going to go that route. Thank you for your help! I always forget about rockauto.LOL
Yeah if they have it in stock, should order it. Just make sure what diameter the wrist pins have, 6 bolt 21mm or 7 bolt 22mm.
Did they make a 7 bolt non turbo 4g63 engine in 93-94? I will check before I order and when I get them. :thumb:
Yes there is 93-94 4g63 7 bolt non turbo. And that's actually a tricky fact, I sometimes see some stores mix up listings. Well but even you receive 7 bolt pistons by accident, you can still use them by machining rod small end.
Wow. I learned something new! Yep I did a 2gpiston/1g rod setup on my vr4 so I already know a machinist that will do it locally. =)
