- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Mitsubishi Galant VR-4
- Turbo Type
- 16g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Autocross
- Mods-Bolt-on
- 3" exhaust, 1g exhaust housing, Radium FPR wit dampener, Radium Fuel filter 10micron w/fuel cooler mount, Front Mount Intercooler, Poly Engine mounts, Evo316G, PTE 1200, COP with Dynatec ARC-2, e85, Tial Q, Raceart Sensor mounts(Boost Solenoid, GM Ethonal sensor, GM MAP sensor), Mishimoto 1G Radiator and Hoses.
- Mods-Engine
- 2G pistons(.030)/ 1G Rods, Balance shaft Eliminated
- Mods-EMS & Logging
- Link G4+ ECU on SD. Perfecttuning.com 60mm Gauge (CAN)
- Mods-Drivetrain
- Full Poly Chassie bushings, Evo 8 Rear Diff, Overkill Performance Built Transmission w/ Welded Center Diff.
- Mods-Handling
- 18" Enkie RSF-2, Whiteline Front and Rear Swaybars, Feal Coilovers.
- Background
- This is my first turbo car that i picked up in May 2014 and have been working on it. It has needed a lot of work sice there was some stuff that was said that was done. Digging deeper into it there was a lot not done and the car has been sitting for a long time and has switch owner a few times. I want to be the owner who restorers her back to how she should be. Time to build a fun car. =)
- Dyno HP
- 234 whp
