jed344
Supporting VIP
- 1,515
- 563
- Jan 10, 2008
Waterville,
Iowa
Best way would be to watch a video on how to read plugs. But you put a fresh plug in, as little idle and drive time as possible i usually put one in before a pass or pull. Make the pull or pass then shut the motor off right away and pull that plug. When you look at it you will see a burn mark on the ground strap. This indicates how much timing the motor want's as it shows how the burn is happening in the cylinder. The mark usually shows up faintly in blue or black line. Ideally is have this mark right at the bend area. When the mark is on the flat part above the center this means the motor wants more timing and if its past the bend in almost to the base that would indicate you have a lot of timing and likely to much. When you have WAY to much it will even burn off the ground strap.I know not of this sorcery. What are you looking at on the plug?
